AnyDVD adds BluRay support | SatelliteGuys.US
vurbano
On Double Secret Probation
23,815
104
Newport News, VA
Dear valued customer,
we would like to inform you, that a new version of AnyDVD
has been released. Here the list of fixes and improvements:
6.1.3.0 2007 03 05
- New: Added Blu-Ray support
- New: Added removal of Blu-Ray region code
- Change: Automatic update notification is now less intrusive
(it uses a ballon tool tip) on Windows XP and Vista
- Change: I/O on 64bit OS (WinXP64/Vista64) moved to kernel mode
- Updated ElbyCDIO layer, fixes "cannot get exclusive access" in
CloneDVD and CloneCD under XP64 and Vista64
- Change: ElbyCDIO uses less CPU cycles under Windows XP and Vista
- Change: After using CloneCD or CloneDVD, AnyDVD does no longer
rescan the disc under XP64 and Vista64.
- Fix: HD DVDs without iHD menus did not work
- Fix: AnyDVD did not shut down properly when user logged off
- Fix: AnyDVD could be unintentionally disabled for some drives
- Fix: AnyDVD could detect Arccos copy protection on short multi
angle titles (e.g., extras on Monster House, R4) by mistake
- Some minor fixes and improvements
- Updated languages
The update is free for all registered customers, of course.
Just install the new version on top of your current version,
regardless which version you have installed:
http://www.slysoft.com/download.html
Have fun with AnyDVD!
Gordon Reeves
Customer Care Center
I got this same update alert today and did a big double-take.
I don't have a burner yet, so I'm not adding the HD capability to my AnyDVD suite, but oh boy when I do...I'm quite impressed w/ the SlySoft folks. Good stuff. Well designed, works great, and these updates just keep coming.
BDP-S300 from Sony
Paramount Announcements
