Are you using that shown 22kHz switch? or an Ecoda?Here is a pic of the way I have things hooked up. Can anyone tell me if they see any reason why it might not work properly? This is not a trick question, I'm really not sure.
The Ku LNBs are all standard and the C-Band is a single output LNBF.
I wasn't sure if Inno was turning off the 3500, or using it to control the switches and polarity.Now that I think about it you may have to do it this way since the 905 cannot handle diseqc. The 3500 will control polarity.
My intent was just to turn off the 3500 to use the 905 and this does work to control the polarity of the C-Band LNBF.
The reason for the 22khz switch is twofold. First because the 905 does not do diseqc and second because I plan on adding more to it at a later time.
I did look at Anole's diagrams in the FAQs section and it was my understanding that the Ecoda switch was only necessary when using Universal LNBs to pass the 22khz info to the LNBs. In my case with standard LNBs, it is not necessary? Mine is NOT the Ecoda.
The reason I am asking is that for some reason I am not getting the correct Ku signals in the house. For example last week I went out and tuned one of the Ku dishes to AMC15 to do some feed hunting. I found the signal out at the dish with my Coolsat 5000 but when I connected the switches back up and tried with the Pansat in the house I could not get any quality at all. This LNB is connected to diseqc #3. The dish hooked to diseqc #1 seems to work fine but it is not switching properly.
The diseqc switch was replaced earlier in the year because of a similar problem but I really did not use the Ku stuff all summer due to other things that kept me busy. The 22khz switch does work as I tried putting the C-band LNBF on the 22khz side and went into the hidden menu of the 905 and turned on the 22khz tone and I did get good signal.
Now I'm kinda stumped. I was wondering if it was my configuration or if I have something else wrong. I need to chase some wires because I think there is perhaps one coupler somewhere in the basement and possibly some RG-59 (ugh!!). The previous owner of the house ran a LOT of RG-59 and in some cases I used it because it was easier than running new stuff but it looks like maybe that's gonna come back and bite me in the butt. Time to chase some wires!
only ecoda 22k switches can pass diseqc commands
all 22k switches will work between diseqc & LNB
ecodas work between receiver and diseqc
After I read TVROPro's EDIT, I saw another problem.
I couldn't use the LOOP OUT on the Coolsat 6000 when I went to slave the DSR-922.
I wanted to make sure the DSR-922 worked correctly in DC2 mode.
The only DC2 Ku signal at the time was OETA, Oklahoma PBS on 79W
My father's motor was the only dish I could use to hit it at the time.
Everytime I would apply power to the DSR-922 while looped through the LOOP OUT, the Coolsat 6000 would power off immediately.
I barely understand electrical matters, but the short version is that hooking the DSR-922 through the LOOP OUT tripped the Coolsat's Voltage protection EVERY TIME
Inno, care to be more clear about what doesn't work?
Limited time offer
