Any Disquec or USALS motors in works for dishes larger than 1.2m? | SatelliteGuys.US
scottc98
1,342
Columbus, OH
Just curious if anything is in the works. Largest dish that I've seen that uses a Disquec 1.2 motor is 1.2m. Is this correct? Any rumors?
Some folks have had varying amounts of success using a V-box to move standard actuators. The V-box converts diseqc commands into actuator movements. I think problems arise if you get too big of a dish though. According to a Superjack tech. support guy the current the V-box outputs is just barely adequate.
I would think so. There are more factors involved than just the length of the arm, but I can go as far west as w7 and can go at least as far as Intelsat 805 to the east. I'm using a 24" arm, controlled by a 4dtv 922.
PAS 1R satellite?
ku BAND LNB specially designed for a PRIME FOCUS PARACLIPSE
