Antenna | SatelliteGuys.US
Antenna
sksatellite
616
How you judge the life circle of an OTA antenna, ten years or twenty years or something.
I am intend to just doing the antenna installation and get rid of satellite dish. Most will use antenna craft brand.
Use antenna web.org and look at the last column to see what frequency range your antenna needs to be.
Then buy quality, Winegard or Channel Master Crossfire brand.
Try to avoid antennas that have too much plastic for holding elements on the beam, it will deteriorate with time, all aircraft quality anodized aluminum is best.
get them all with no rotation???
Can a local channel do this?
