Antenna | SatelliteGuys.US
Antenna
Zesuit
9
I found this website antennaweb and found all my local station that support DTV is in the yellow and green range so is there an indoor DTV antenna I can use to put in attic to pick up DTV signal or they have to be outside only?
I am still learning about antenna and picking the right one for OTA.
Hi Zesuit, I am using the Zenieth Silver Sensor.. Its a indoor HD antenna and works great for me, it says on antennaweb that i am 14 miles from my towers. And i am getting all my locals which is 5 and all at about 85% signal strength, i am sure if i added a inline amp for the antenna it would pull close to 100% but i don't think that is needed at the moment.. The Silver Sensor can be found at Sears "where i purchased mine" or can be found at many other places..
Alright thank you I will go to sears and check them out tonight.
I am less than 10 miles to all station so it should be good antenna for me then.
Which OTA unit that CC work?
Distant OTA
