Antenna | SatelliteGuys.US
Antenna
jhump
55
I just purchased an indoor antenna the Zenth ZHD-TVI and get FOX-HD, NBC-HD, ABC-HD, all at 50% about half the time. I am located in the Cincy area. If I purchased an outdoor antenna will I get 100% most of the time? I am new to this satelite thing. Dish installer told me I didn't need a HD antenna. I kinda wish I would of stayed with cable after all this.
Can't go back until my 6 month agreement is up. I will give an outdoor antenna a try and see what happends.
Welcome to satellite guys jhump.
Go to http://www.antennaweb.org/aw/Address.aspx
Enter your address. It will tell you what kind of antenna you need and which direction it should point.
Generally, if you get a larger antenna and put it in your attic or on the roof you should be able to get a great lock. Especially since you are getting 50% with a small indoor antenna.
Don't get discouraged, it will be well worth the effort.
And ignore the trolls that pop into some of these threads.
Any Costco 921 sightings yet?
DNS Gone For Most New Subscribers
