Antenna whows! | SatelliteGuys.US
Antenna whows!
outinthecountry
2
louisiana
I have a DISH network setup and bought a Trek antenna. I am on the fringe and it doesn't quite pick up local channels most of the time. My question is simple. I have now bought a Winegeart Outdoor Antenna with a single coax. Is it possible to wire it into the DISH system so I can recieve local channels on all my TVs? :confused:
Much more information is needed.
What antenna did you buy?
Where are you located, zip code?
What DISH receivers do you want to connect to?
How many TVs do you want to connect to?
Cheapest way to get just HD LiLs and as little else as possible.
how do you install 2nd receiver for a bedroom yourself
