Antenna Arrays Could Replace Satellite TV Dishes | SatelliteGuys.US
Faw
117
Bayamon, Puerto Rico
Saw this on slashdot, didn't knew where to post it so i thought technical discussions would be good, move it if it's the wrong place.
Basically its a very large array, use a lot of small antennas to replace a single large ones an use software to sort of simulate the large one. By altering how the signals from the small antennas are combined you can "point" the antenna at different sources. Hence you not only have a large detector from combining several smaller one but you can also point the array without having to mechanically move it.
From what I understand it would mean no dish aligning (maybe just point antenna in a general direction) , no extra antennas for extra satellites since software would take care of that.
VLA
The link you supplied is for a VLA of dishes. So how is it you think that it's replacing the sat dish. It also takes some serious phase work for combining of these systems. That would have to be part and parcel of the s/w to do it.
I could pick up Martians on their cell phones with that, but I don't think I could afford the electric bill.
You think I could borrow that picture to submit to my subdivision associations.
"hello everyone, I would like to show you what my antenna system will look like"
Dish Remounting Covered in DHPP
622 will not authorize with Dish 500?
