Another SG2100 Motor Question? | SatelliteGuys.US
bigOleB
1,708
SC
I have a SG2100 and would like to know what the solution is to my following problem:
My true south bird is AMC 75W
:confused: The motor is designed to rotate 70 EAST & WEST. This makes it impossible for me to get past 150W or so if I set the motors reference point to my true south bird? Do I have to set motor to my true south bird or can it be another satellite. I am guessing no, due to skew and angle?
Refer to this picture to see what i'm talking about-
http://www.satelliteguys.us/attachment.php?attachmentid=3196
There are limit switches under the (motor see manual) they may be moved slightly to get a fraction further east and west. Doing so is at your own risk as the screws can fall into the motor rendering it useless. I have even heard of some people removing the limits altogether but I advise against it. You can off set the dish to another satellite other than your true south satellite but of course what you gain at one end of the ark you loose on the other, and will take some extra tweaking.
If you go ahead and do the above let us know your results please.
I may try this trick on another SG2100 that got messed up by ice and I had it fixed. If I lose this one to my engineering it will be the second time. I will let you know my results.
New user - Need some help
Fun to be had with Satellite dishes?
