Found another new Dish and DTV automatic dish setup I hadn't seen before..at $1199 a little pricey for me
I noticed the manual was only the DTV model.. I'm not real impressed with the tripod that he mentioned in the video about using tent stakes in the ground..We know how well that's going to hold up with a little wind.. I'll try giving them a call this week and see if I can find out some info about dish availabilityI've seen it mentioned in one or two RV forums, but no one seems to have any actual experience with it. Every time I've checked their site, the Dish version has been sown as "out of stock", and the only manual available in the support section is the DTV version.The price is about a third less than the Winegard Trav'ler series auto aiming dishes, but that doesn't mean much if it's not available.
Yeah, I didn't see any indication that it would work with the Dish EA either. As you suggested, if I was starting from scratch I would consider the automated dish, but in hindsight, now knowing how easy my manual setup is, I have better uses for the money. The number of sites we've been on where the EA was the only available LOS would make me shy away from any dish that can't use it.No indication of the LNBF head of the Dish model can be changed and the EA used. With a Super Buddy meter, setup is minutes. We often used the ground tripod for the EA than for trees when the Winegard Trav'ler didn't work. If I was purchasing a new RV and if the LNBF is changeable, I would consider this tripod mounted automatic dish.
Limited time offer
