another one | SatelliteGuys.US
another one
dunnsept
358
Central Meechigan
bites the dust.. I mean.. is hooked.
I just hooked up the pansat 2500a, dish was already pointing at G4.
Voy OH LAY!!! very nice channel, same one I get elsewhere , superb picture quality. no tweaking, nothing.. I think quality was like 78% or so and I had only used the toshiba's auto skew & ant. nothing else
wheee!
I have a feeling this is gonna be a late night.. too bad it's all in the basement, it's cold down there! I need to pull those wires thru up to the living room, then I can sit in front of the fireplace and do this stuff.
You need to get some IR repeaters or a couple of powermid remote extenders, and some digital modulators. Leave the recievers in the basement and build a mini head-end. Then the only issue will be.....Where is the remote!
Reception question for you fellas with a mini bud
Moving a big dish?
