Another E* dish D*dish Question | SatelliteGuys.US
martin1
79
I just converted to D* a couple of months ago from E*. They installed my
D* with just an 18 in. dish. My E* dish it looks like it's 22".My question is if I took off the twin E* lnb and installed a dual D* lnb would this screw up the
focal point of the E* dish. I notice that the twin E* lnb extends out about 5" more than what the D* lnb would be or is there a detail that extend out the focal point.
Yes I know this but can the elevation and azimuth be adjusted to compensate for this?
The DISH 500 is a 20" dish so there is only a slight gain in surface area. DISH makes an"I" adapter for using this dish with a single LNB I believe the DISHSTORE sells it.
Pic Goes Out Then In (HD), Alignment Is Fine
Loss of picture
