Anik F3 C band | SatelliteGuys.US
Anik F3 C band
ZetaMale
18,033
13,959
USA
Did someone turn down the power for the Fusion mux? All of a sudden the signals are in/out. Other sats are OK. Well, CW on Galaxy 17 is still acting weird even though I triple checked the PID settings (for example, CW East PCR 101, VPID 101, APID 102) - video is choppy and audio is difficult to lock. I think it's an Azbox issue because ABC HD on Galaxy 16 is A/V out of sync, also. I don't have another receiver to test with.
It turned out to be a problem when I upgraded to the latest firmware to see if it would fix my problems with CW but ended up with other issues so I downgraded back to 2372 only to find that some transponders weren't coming back in. Turns out that I had to reformat the application area and then re-install the firmware and now everything works again except for the CW issue. As I recall, when my Azbox died the other day I had to reformat the application area before the firmware would reinstall properly. I know that the Azbox is in beta but it's giving Linux a bad image :eek: (I use Mandriva Linux, BTW). :tux:
New hi tech TV......
My familyTV on Gal3
