Anik F3 at 118.8°W | SatelliteGuys.US
Anik F3 at 118.8°W
Apprentice
345
Wichita Kansas
What does it take to pick up this Satellite. I saw a website that claims it takes a different LNB type?
118 / 118.7 LNB's are used mainly for ANIK F3 or 118.7. They have a LO frequency of 10.750 GHz. Note: these LNB's are circular polarization and can also be used for all DBS/DSS type satellites including 61.5, 82, 91, 110, 119, 129, 148, etc
Is this right or just a sales trick? Just wondering as there are a couple of signals on that sat I would not mind checking out.
Chuck
C-Band or KU?
C-Band is a normal setup
5150 LNB LO
KU is linear circular. It is circular polarity but in the linear KU frequencies (11.7-12.2). Normally DBS is circular (12.2-12.75)
KU only has a slate channel from Dish (rest are scrambled) but C-Band can be picked up just fine
That's correct. The bird is setup circular polarity, but at lower freqs than the other circular birds. I used to be able to get the edge of the signals using the linear side of my Invacom qph031. Every now and then , something was viewable.
Is there a thread of 97 english programming
Infant Crib Recall - C band backhaul
