Andrew Channel Master 1.0m/34 inches | SatelliteGuys.US
johnsamaan
6
I was given an Andrew Channel Master 1.0m/34 inches, with a single feed Ku-LNR gain 62db made by California Amplifier.
Can I use this combination to receive Free Air TV Channels. I was planning to buy a Coolsat 7000 miCro PVR receiver. Do I need to add more LNB?
moved to FTA area
yes that dish should work just fine. I havent heard of the LNB so I cant comment but as long as its KU Band it should work
california amplifier is a brand starchoice used for awhile I beleive, therfore its ku linear, if I rem its not stacked either. but a blindscan will tell you the soon enough.
Coolsat 6000 Invacom QPH-031 Configuration
echo star 7
