AMIKO - Amiko Nano HD Firmware 1.4.49: Youtube Fix | SatelliteGuys.US
AMIKO Amiko Nano HD Firmware 1.4.49: Youtube Fix
  • Thread starter Thread starter KE4EST
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,035
7,364
EM75xb
I have decided to pull this file until I can get a 60Hz default version.
Amiko Nano HD Firmware 1.4.49: YouTube Fix
Changes
- Updates YouTube.
Installation Instructions
Follow this procedure EXACTLY or you will end up with no satellites at all and you'll wipe all of your channels and settings.
MAKE A BACKUP. This contains the satellites and your current channels, settings and other data. It is needed if you mess up the upgrade. Plug in a USB flash drive. Go to MENU > SYSTEM > SOFTWARE UPGRADE > BACKUP TO USB, arrow down to "Backup to USB" and press OK. You'll end up with an .abs file starting with "bak-"
BY USB
1. Unzip the update package and put the .abs file in the root of a USB flash drive.
2. MENU > SYSTEM > UPGRADE BY USB
3. Select the .abs file on the Upgrade File line.
4. BE SURE UPGRADE MODE IS SOFTWARE(NO CHANNEL LIST)
5. Arrow to start and press OK on remote. Your STB will install the new firmware and reboot when done.
6. Your receiver will boot up in 1080i-50Hz mode. Just hit the V. Format key on your remote one time. This is will put you in 1080i-60Hz mode.
BY ONLINE UPGRADE
1. MENU > INTERNET > HTTP UPGRADE > MANUAL UPGRADE.
2. Ensure upgrade mode is SOFTWARE(NO CHANNEL LIST).
3. Press RED key on remote. Your STB will download & install the new firmware and reboot when done.
Optional but highly recommended
Now that you have successfully upgraded the firmware and boot-loader and restored your channels you should make a new backup with everything in it. This will save you the extra steps above should you need to restore or revert your Nano HD. I recommend doing this on a spare USB Flash drive that you can leave alone and put somewhere safe if ever needed.
1. Go to MENU > SYSTEM > DEFAULT SETTING.
2. Select "Save default value" and press OK. This writes all your preferences and database into the default memory.
3. Go to MENU > SYSTEM > BACKUP TO USB and make a new backup. If you want you can change the name of the backup file to anything you want.
Reactions: mc6809e
