Thanks A Raine, yes I do have the A3 and I have a DishPro 1000 Plus with 3 LNBs.
Hi achex. Which c band dish did you order?Hello guys,
After a very long search for satellite dish, i finally ordered a 8' mesh dish, should arrive in a week. Also bought the suggested FTA LNB, so far I have those two and the AMIKO A3. Now my question is,
1. is there anything else that I should get?
2. what satellites should I aim my dish to/any favorites?
3. is internet connection needed?
4. is there a better FTA LNB(which one is the best)
5. any other suggestion? I'm just a newbie being myself lol.
Thanks in advance.
PS: Anybody know a good Black Friday deal on 4K TVs?
Thought that might be the one. Believe they also do business on ebay as Tek2000 and they have a website as well. Got mine from Tek2000. Decent dish for the money. Been using mine since about May I believe. Check it out carefully when it arrives as they have had some issues with minor damage during transit and also make sure you have all your parts. Reflector is aluminum so fairly easy to assemble yourself. Mount is steel. Only needed help when I put it on the pole. As far as lnb, C1-PLL is c band only and is top of the line pll and locks signals others have trouble with.Hi FTA4PA, thanks for the quick reply,
It's "240cm (8ft) C/Ku-Band Prime Focus Mesh Satellite Dish" from a company called "Satellites Galore" a Canada based seller on eBay.
... so the c-band LNBF you mentioned above, is that for c-band only or for both, is one better than another. I will take a look at the link you provided.
Is there an LNB that is both C and KU band that works without any quality loss?
This is what Brian(Titanium) is talking about:
http://www.tvantenna.com/products/satellite/cband/feedhorns/CorotorII .html
Limited time offer
