AMC-21 APIDs in DVBViewer | SatelliteGuys.US
Zero
241
India
Either scanning through Transedit or from DVBViewer does not tune APIDs. APIDs appear as 0 in all the channels except PBS Montana channel. I added APIDs in Channel editor and it does not help at all. Any help is appreciated. This happens with one of ATSC channel aswell.
The audio is all AC-3 except Montana PBS, so it looks like your software is not supporting AC-3 properly. Can you run TSReader with your card? Or use transedit / dvbviewer to record the whole mux and then load that into TSReader? With TSReader you can get all of the pid information.
Thanks a lot gillham. I will try it after some time. I am watching a movie now on HTPC and do not want to disturb the family now..
I tried TS Reader and Transedit Analyzer as well. They tune the Audio PIDs correctly. Also, DVBViewer TE Version was able to tune properly.
I added the APIDs (for English Audio) in Channel Editor and changed Audio to AC3 and was able to get the sound. I guess there is some problem while tuning in DVBViewer Pro / Transedit. Let me see, if I get answer in DVBViewer forum.
I think that's a known issue and is being addressed..
Mounting a fixed dish on a motorized dish mast
Mercury Dynamic or Traxis 3500?
