amazonas | SatelliteGuys.US
amazonas
jeroph
3
(No problem finding Amazonas at 61.0 degrees. Very strong signal on 11972 V. At first it worked fine, but now if I go to that bird I get a strong signal (if aiming) or a good picture (if viewing) for only 3-4 seconds, at which point the signal level drops way down and the quality goes to zero. I am using a Pansat 3500S.
Is this because the signals are HDTV? Or is HDTV in this context something different - referring to Hispanic * TV, for example.
Thanks for any thoughts you have.)
Craig
How did you get the pansat 3500s to work on amazonas
pansat troubles
CBS Newspath Galaxy 16
