AMIKO - ALI Editor for Nano HD? | SatelliteGuys.US
AMIKO ALI Editor for Nano HD?
northgeorgia
1,557
211
North GA
I was wondering if there is a specialized ALI Editor for this product, or if the one used with say, the Openbox or the MicroHD would work just as well?
Good to hear. Starting to consider getting this, as the changing weather and long cable run seem to be affecting improper polarity switching once again between the PLL LNBF and my microHD (that is, it sometimes wants to scan/display vertical polarities only). I saw that the Nano allows the user to up the voltage by 0.5, which would probably be just enough to work with the longer cable run. Either that, or I may just go back to the DRO PLL (but then I can expect to lose FSTV and Montana every other night) :)
MicroHD: Pre-programmed scan vs Blind scan
MiniMe 422
