Alaska, What can I receive on C Band? | SatelliteGuys.US
If I am not mistaken, you should get all the 4dtv feeds, if not most of them, though a 12' or 14.5 would be a good choice dish size.
What about just old ANALOG?
Norman
Norman
Analog programming is leaving practicaly monthly, I do not think it would be worth it at all to put up a system just for analog wildfeeds and subs.
Ah ha, my friend, you are sadly mistaken. There is plenty of free analog programing left depending what you want to watch. If you are a college sports fan it is a must on a fall Saturday afternoon. MLB teams are using analog on a regular basis more this season since the 80s. Plenty of regular programing on the wild feeds. I have the FTA set up, but I will take the BUD and analog over it anytime.
I wish I had a motor on my 6 foot BUD....I got it for the networks on G4 and right now I "ghetto move" the dish to IA6, G3, IA5 for the wild feeds :)
The only drawback may be your location. I punched in Anchoarge and G10 (123W) is at 17.2 degrees. Once you get to 103 (AMC1) you're down to 10 degrees
Yes there are still analog feeds at the moment, and the wild feeds will most likely stay much longer than the subscription feeds, though if you are not a sports fan then there is not really that many feeds up there like there once was years ago.
watched fatal instinct movie on IA6 channel 24 the other night so there is still some wild feeds mostly on the weekends.:)
HBO DCII signal low?
Brackets
