So the motor is set up and you used USALS and have a list of satellites. But, some in the list are set to fixed dishes. How do you keep the dish from moving when it is not necessary to move?
RT.
RT.
Disable the option to use USALS or DiseqC motor in your receiver menu. What receiver are you using?So the motor is set up and you used USALS and have a list of satellites. But, some in the list are set to fixed dishes. How do you keep the dish from moving when it is not necessary to move?
RT.
S9.Disable the option to use USALS or DiseqC motor in your receiver menu. What receiver are you using?
Yes, it all sunk in to my old head. I am about to set the dish on the new pole and was a tad bitRTCat,
You can disable or enable the motor function for one or more satellites within your list......You can combine any combination of these as your situation requires.....You can mix and mingle every option that you like.
Have fun and play around with it. Experiment and learn it all for yourself or take my word for it. With most receivers, you can do just about anything you desire.
RADAR
S9.
Uhmmmm, if you disable the USALS option, won't that just stop the motor from moving? Maybe I am not understanding your answer......
RT.
Just disable the motor for the particular Satellite that is fixed, it will not affect the others.
Change the location to 0.0 degreees West on those dishes that you want fixed. I did it with Hispasat since I have a secondish connected with a Diseq switch to the motorized 1.2 dish LNB
Limited time offer
