Advice on switches to use for legacy LNB's for 110, 119 & 129 | SatelliteGuys.US
f13dfx
65
All the LNB's I'm using are legacy, and as I understand it I connect 110 and 119 via a SW21X, and then I connect the output from the SW21X to port 1 on the SW21 and then the output from the LNB pointed at 129 to port 2 on the SW21. Then I connect the output from my SW21 to my receiver.
Can someone confirm that this is correct.
Thansk in advance!
It is definitely possible to drive a 3-sat 2-tuner setup with legacy LNB s and two SW-21's. You can even drive 4 tuners with legacy LNBs and an SW64.
Dish 6.3 Remote batteries don't last
Dumped 129................
