advance scanning with dvb receiver. | SatelliteGuys.US
htownjoe
163
splendora tx
i started fooling around with the advance scan last night and finally realized what the numbers meant on the lyngsat charts under the tps. i was wondering why i wasnt getting all the channels under the tps! anyway i have to manually program these in, my blindscan dont pick up most of these. the one problem is that when i do enter it in and adv scan it i can only do one ch per sat. it list it as ch a. i was wondering why i wasnt getting the cw channels on g 28 i think it is. anyone know how to do these where i can add more per satellite? thanks guys,
The CW channels on G11 need to have to be manually entered.
Sadly you have to do it one per channel so the CW is 3 entries. I just got done entering 20 audio feeds yesterday from one channel (they have a bunch of audio tracks and you just change the language).
Yes it always lists as "ch a" because it doesn't know what the banner should be (like some channels say "service 1")...you can renmae them once you are set up
C BAND ANOLOG AND OR ku bAND
Scaler Ring Removed
