Additional Receive/rphone Fees. Quick Q... | SatelliteGuys.US
gb387
23
After using the 'Dish Builder'.... I thought there was an additional $5 fee for each receiver (over the first one).... I am looking at one HD Receiver(single tuner) and two standard receivers, the additional fee is only $5 for all three. Is that right? If I do not have a phone line does the 'no phone line fee' apply to only the DVR's/twin tuner receivers?
It is all getting installed next week just want to make sure I know what I am going to be getting billed for.
Are you sure the "two standard receivers" isn't actually a 322 - two tuners and two outputs, only one "receiver" as far as fees are concerned.
The 322 does have the $5 no-phone fee.
Well, I called to double check, you are right there 'dish builder' must assume you are going to get a dual tuner.
I guess they need to add the no-phone line fee to their builder.
