Adding Second TV | SatelliteGuys.US
Adding Second TV
lamp
74
28
Tennessee
How would I add a second TV? There used to be a TV at that location. There is a barrel connector where the TV was connected. This connector location is between the dish with two LNB's and the receiver. I don't know how it was connected there. See pdf.
There was always only one receiver with a second remote control. She still has the second remote control.
To make the connection at the barrel connector, looking at a picture of a diplexer, I suppose the Sat port is connected to the wire coming from the dish. The TV port is connected to the 2nd TV. And the in/out port is connected to the wire going to the receiver. Is this correct? I will try adding a diplexer at the barrel connector first and see if that works.
There is already a diplexer type part at the receiver.
Thank you for the help
If that diplexer type part at the 222 is connected to the 2 satellite inputs it is not a diplexer, it is a combiner. That allows both tuners to get fed from 1 coax. You would need a diplexer at the 222 also connected to that single coax feed the combiner.
I am trying to do this for a friend. There is no hurry for this. I will try to get a picture of the part behind the receiver. It does feed to the two satellite inputs. I printed out that second diagram. It should be helpful. Thank you for your help.
Dish Magazine
Latino packages and MSNBC
