adding receivers to 1000.2 dish | SatelliteGuys.US
larryf
203
Texas
i have a 622 and two 211s on a 1000.2 dish .can i add 1 or 2 more receivers that i already have to system? what would i have to do and what would dish charge me? trying to add tv to a shop in back yard.
You would need to add a switch to the system. The 1000.2 can only run 3 receivers. By adding a single switch you could run 1 more receiver. It would take 2 switches to add more.
To go to 4 receivers you need to connect a DPP44 switch to all three satellites (D100.2 outputs 1, 2, and 3 to inputs 1, 2, and 3 of the switch respectively) and put a power inserter on output #1 of the switch then run the 4 outputs to your 4 receivers. For more than 4 receivers, you can cascade another DPP44 off the first one.
make sure line 1 goes to port 1, and so forth on the 1st,2nd 3rd switch dont cross or mix up wires, or you'll have all sorts of signal issues
VIP 722 DVR Help
Reformat an external hard drive
