Adding on 625 DVR | SatelliteGuys.US
Adding on 625 DVR
Jeff lost in cable
55
Hi,
I have a 625 connected to a Dish pro dish with a twin LBN I have two cables going to the the dish now. I have been looking for a switch I can add that would allow me to add another reciver without running more cable to the dish.
Any help please? :)
Jeff
You can use a Dish Pro Plus 44 (DPP44). This will allow you to view four satellites and feed up to 4 receivers. By using a DPP44, you can use a dish pro plus seperator which will allow you to run one cable from the switch to your 625 instead of having to run two cables. You can get these products dishstore.net for a good price.
Mark
That sounds better. I thought I could use some diplexer or something else as I did hook up a Dish PN 20341 this splits the LNB. It did work for a while then on the 625 kept getting signal loss and not both Sats would lock in. It got pretty erratic until I put both LNBs back in the 625.
Jeff
"Reality TV is no longer available"
Yet another 942 question...
