Adding more than two dual receivers | SatelliteGuys.US
snaps98
6
I have the Dish 1000 and i am using both ports 1 and 2 out from dish to two different dual receivers (vip 622). i want to add one more reciever, what multiswitch do i need to add another HD dual reciever? so i want a total of 3 dual receivers in my house, or 2 dual receivers and one single receiver if that helps.
DPP33 switch comes out in a couple of days. You could also upgrade to 1000.2 dish. Many DISH techs when they encounter an old 1000 dish with low signal are just swapping them out. You could roll the dice and put your dish slightly off alignment and just kill 129 and get a service call. If you get DHPP, (digital home protection plan), the whole ordeal should just cost you $5.99.
Eastern Arc Antenna
Remote Codes
