Adding another receiver | SatelliteGuys.US
jgags6
1,107
68
Rockford,IL
I am planning to add another Dish receiver. I have 4 right now and im waiting for my 622 (wich i will be swapping for my 811) and dish 1000 to be installed. I was going to buy a 411 and try to install it myself. But I dont know what i will need. I was wondering if i will need to get another Dish Pro 34 switch or should i get the 44? What else should i get?
The DP34 will be cheaper, but you will have to run another line to the 622. DPP44 will allow you to use a separator and not have to run the other line.
A DPP44 should come with your Dish 1000 upgrade.
Almost what I was gonna say.:D
moviebeachmotel
A dish system is installed at this resident but only have two outlets for two TV's. Presntly, I ran another line via spliter but no signal or reception in basement. What must I do to get reception?
Rebate Runaround
go to dishnetwork from direct tv for hd?
