am thinking about adding a wing dish to my 1000.2 dish.is this worth my while and what satellite should I add?am getting 110,119 and 129 now.but I lose 129 in bad weather.am located in Niagara falls.
thanks
thanks
Maybe he's in Canada?If you are in Buffalo you can get all of your channels, in HD, using an eastern arc setup. Buffalo HD locals are on 61.5 and SD is on 110. Instead of a wing dish I would change to eastern arc and be done with it....
He can still change to eastern arc and be OK... He's already working on western arc...Maybe he's in Canada?
Sent from my SAMSUNG-SM-G900A using Tapatalk
I would suggest doing the opposite: switch to a 1000.4 EA and add a wing dish for 110 if you want to be able to record your locals in standard-def. Also, this may be nit-picking, but since when is Niagara Falls near Detroit? (Where your Location says you are.)am thinking about adding a wing dish to my 1000.2 dish.is this worth my while and what satellite should I add?am getting 110,119 and 129 now.but I lose 129 in bad weather.am located in Niagara falls.
thanks
I did that same thing some years ago because my locals were on the 61.5. It works perfectly and somewhat future proofs your setup.am thinking about adding a wing dish to my 1000.2 dish.is this worth my while and what satellite should I add?am getting 110,119 and 129 now.but I lose 129 in bad weather.am located in Niagara falls.
thanks
thanks
I notice that plott hound has now updated his Location. (I thought I should post this before anybody posts asking what I was talking about.)I would suggest doing the opposite: switch to a 1000.4 EA and add a wing dish for 110 if you want to be able to record your locals in standard-def. Also, this may be nit-picking, but since when is Niagara Falls near Detroit? (Where your Location says you are.)
Limited time offer
