Adding a C band dish to my K/U FTA | SatelliteGuys.US
lakegazers
22
California
I have a Fortec Mercury II receiver and a DSR 905 sidecar. I presently have only a KU dish. I have a C band Sami 7.5 dish and feed horn with a polar roter , just installed on a new post. I assume with the Mercury II receiver I need to run the Cband on Desiq and loop to a VBOX-II Moteck, in order to move the Cband dish. I am not sure how to program the positions on the steerable for each bird. I use usal for the K/U band dish.
pjohnson
USALs does not work with the V-Box2 unit (I think?). You will have to program it with the 1.2 Diseqc Commands in the Mercury II. Good Luck! That being the case, I would also think you can leave the USALs as is for the Ku Dish?
Al
scoring a Pansat deal...need advice
New to FTA: Getting good signal quality but 0 signal strength
