I have a 1 room setup currently. If down the road I choose to add a 2nd or 3rd room to the service, can I just split the signal coming in the house with a splitter or is other hardware required?
Correct, they will use a switch 21. Tell them about you interest about adding a second receiver and see if they will run a second line and switch for you.Silver3783 said:Does that switch join the RG6 cables coming from both Dishes into 1 RG6 going to the reciever?
Limited time offer
