Adding a 2900 to my Dishpro/622 setup? | SatelliteGuys.US
pip
20
I recently upgraded my 6000 receiver to a VIP 622 HD DVR. The installer repointed one dish to pick up the HD satellite. This was an old 500 dish with a dual legacy LNB with two cables running from the dish. My second 500 dish is pointing at the other two satellites and has a new LNB, a Dish Pro Plus I believe. One cable from the HD dish is running to the DPP dish and two cables are coming out to the 622 (with a splitter at the receiver) and a legacy 4900 (upgraded 4700) upstairs.
As far as I understand it, the legacy 4900 is working because one line is connected to the 622, so with this setup I should be able to connect an old 2900 I have lying around. Is this correct?
So, if I split one of the two outputs from the DPP I can run a line to the 2900?
The 2900 has a blue card in it, I assume I'll need to get a new yellow card from dish when I activate it?
My TiVo doesn't play well with the 622, so i want to add the 2900 just for the TiVo.
Thanks in advance for the help :confused:
I guess putting a DPP44 switch would do it...but at $199 they're a tad expensive :eek:
Any other way?
If I add a new receiver from dish instead of the 2900, would the free installation add a DPP44?
Thanks for the help. The receiver is a 2900, it says so on the back. Bought it 7 years ago in my original install, hence the blue card is out of date. To activate it I'll need a new card.
IT IS 2800 - connect it to TV ( no coax required) and press SysInfo button.
(I'll bet for your new 622 :D))
Its a 2700/3700/2800 according to the SYS INFO menu. Do all receivers suffer from multiple personalities? :D
The 2700 and 3700 were introduced about the same time the 2800 replaced the 2700 about a year later. Over time software upgrades gave them all basically the same functionality, so they are lumped together as the same model. The 3700 actually had a better remote (Universal) the others only operated the satellite receiver.:)
Rubbing some of the grime off the sticker....I see that it is in fact a 7 (2700) & not a 9 (2900).....;)
622 upgrade question
Had my 622 installed yesterday
