Adding a 211 rec. to my 722 in a MH | SatelliteGuys.US
BillK
USA
Hi I am a newbie here.
I have a winegard Tvlr on sat 1000 on my coach and a 722 rec. i want to add a 211 rec to the back bedroom so that I can get HD. What splitter do i need to add. Is there a dependable wireless transmitter that can send it to the bedroom TV, it is about 30 ft away. I tried a Genfen but it shuts off and on constantly.
Thanks for any input, it is hard getting good info on the RV hookups.
BillK
I have the same setup, but with a Hopper and a Joey. It all depends on how the RV is wired. The Travlr as originally setup has 3 outputs with the 1000.2 dish. You might want to climb up on top and see if there are 3 connections to the coach. If so, then you might already have a line to your bedroom. I made the Travlr part of my purchase of a 5th wheel and specifically had them install 2 connectors up on top.
Chicago Locals on Eastern Arc
Pleasant OTA Surprise
