Adding 4th reciever? | SatelliteGuys.US
jresurv
8
Hello
We got the 4 room installation a while ago;
Living room with 622 in dual mode controlling hd tv in living room and sd tv in bedrrom 1
bedroom 2 has 211 controlling 1 tv
bedroom 3 has 311 controlling 1 tv
Didnt use tv in bedroom 1 very often so dual mode was ok
We've got used to using the dual tuner in the living room, tape 1 show while wathing another.
Fast forward , kids have moved back in to bedroom 1 for a while.
Can we now add a box to bedroom 1 so we can leave the 622 in single mode and they can have total control of tv in bedroom 1?
Also what is involved in getting a dual tuner for bedroom 2? Can we trade in our 311 for another 622? or is there a hd reciever that has a 2 tuner dvr that doesnt control another room?
Since you already have 4 tuners, leased I presume, you should contact the ceo email address and see what they can do it terms of upgrading you over the 4 tuner limit. You will need a DPP44 switch to add a 4th box as well, assuming you dont already. To change bedroom 1 to a tv with its own receiver it will need a line to that tv straight from the dish. You cant just plug it into the existing wiring.
100' Long HDMI?
Using the 129 in northest Pa
