added on a new dish. | SatelliteGuys.US
danristheman
3,147
1,145
85w
here are some more pics of my new dish setup at the house. would like your opinions on this and tell me what you think of it?
IMG_0106[1].JPG IMG_0105[1].JPGIMG_0104[1].JPGIMG_0103[1].JPGIMG_0102[1].JPGIMG_0101[1].JPGIMG_0100[1].JPG Dan Rose
Pictures look fine and oriented correctly on my iPhone.
The thumbnails do look skewed, though.
Problem with dishes that low, an animal or person could block your signal.
Buddy used to have his dish beside his front door.
If anyone walked up, he got an early warning. :)
the black dish is setup for for 97w the 1 meter is setup for 99w c band I know its not the greatest but it hopefully it works.
dan Rose
How deeply is the pipe in the ground? Did you hammer it in? If hammered, how did you prevent flattening of its top? Is it really stable, especially when carrying OTA antenna? Your project is good, as you avoided drilling in the wall. Cheers, polgyver
I have that pole about 3' in the ground with cement or concrete been there at least 10 years in the same spot. I followed the otard rules as much as I can. Migold I have lot of channels off of 99w c band even wrbk out of branson Missouri at 30%Q. I didn't have to hammered it in to put the pole in the ground just dug a hole and put it in. I have some more pics for you guys and tell me what you think.
Dan Rose
northgeorgia the ku band lnb picks up either 89w or 91w since cband is so wide of a signal you can be way off and still get something to watch. those PLL lnbs work out great for the ku band setups.
Dan Rose
nothing i just put the lnb right next went through 2 storms and was still there.
dan rose
CW on Galaxy 17 gone scrambled???
Mary and Rhoda together again-Me Tv in July
