Add TV to dish 1000.2 | SatelliteGuys.US
bill123
I have 3 vip612's connected to my satellite dish. I will be adding 2 more receivers and want to know what i have to add other than the receivers and cable ....
Your 1000.2 will only support 3 dual tuner receivers without switch help.
Adding a DPP44 and cascading a DP34 off of that will get you four new connections that will support two more dual tuner receivers, each with two lines run to it (DP34 cannot band stack).
Not an inexpensive mod, the DPP44 will run ~$200, plus receivers plus DP34.
is 129 down?
Anyone have problems with their 622 broadband?
