Add 110 wing to eastern arc | SatelliteGuys.US
Teehar
8,496
393
WNC
First post great forum with tons of info!:up
I have searched but still can't find the solution to my problem.
I have a eastern arc (1000.4) I am trying to add 110 for the HD locals from aad.I only have an old legacy dish,will the input on the 1000.4 work with legacy or will it have to be a dp or dpp linb?
you will need a dp single or dual lnb, either will work.
the dual is a single lnb with 2 outputs, not the ''twin'' which has 2 lnb's and internal switch
Thank you sir! I had a feeling the legacy wouldn't work.
VIP222K Almost all channels gone
211 Audio Issue
