Active transponder on AMC 5 79.0W | SatelliteGuys.US
mchomicz
SatelliteGuys Guru
I think I SHOULD be able to find this out myself from LyngSat (http://www.lyngsat.com/amc5.html) - but I think I'm missing something...
Could someone please provide relevant information I need in order to adjust my dish based on signal from a transponder on AMC 5 at 79.0W (presumably an un-encrypted channel and not a feed?)
My understanding is that I need:
Transponder
Frequency
Symbol Rate
Polarization
For example, on LyngSat I see:
Transponder: tp 8
Frequency: 11900
Polarization: Horizontal
But Symbol Rate is confusing as there are 3 numbers: 2170-3/4 4130
(assuming this would be a good channel to use for adjusting the dish)
Any help would be much appreciated
Michael
If I were doing it, I'd try to pick up the New York Network.
tp 16u
12182
23000
Horizontal
Reading LyngSat's charts, the signal rate (SR) is the first number under the "SR - FEC ..." heading. When there are multiple channels on the transponder, each channel lists the video PID (VPID) in that column, then the audio PID in the next column.
When there's only one station on a transponder (as with KTEL on AMC 5), the first line is signal rate and the second line is the VPID.
upper
I would try KTEL as it is a much stronger signal
11900 H 2170 :)
you don't need to know which TP its on, just the 3 things I noted above
mchomicz said:
Why is an NYN channel better?
It's not better, it's just dependably there. I like to use it to peak the signal when I point at AMC 5, but Iceberg's suggestion of KTEL is just as good.
How about the best of both worlds... :)
Use KTEL to find the satellite in the first place since that transponder is stronger, then once the satellite is found, peak your dish using the weaker signal, NYN.
WUMN (Univision MN) getting a local newscast
Out of sync audio on Satworks 3618 FIXED
