I will be getting Directv in a few days I got an HDDVR and two standards...my aunt has an r15 she owns and said she would give it to me (her contract ended and she switched to dish) do you think I will have any problem activating it?
Yes the hddvr and the two standars reveivers are new from directv...the r15 is from my aunt she says she bought it before they started the leasing program
um..
when you call and activate used receiver
make sure they mark your receiver as owned.. cause the normal CSR didnt and it showed up as leased and could not change it to owned,, i had to be transfured to the (accesscard Deptartment)
@ 800-695-9251
and they did it without problem - even used the old cards..i didnt even provide the access card numbers to them..
all i gave them was the Receiver ID # and it was all set..
Well I'm a new customer so I don't think Ill be able to get it for free (I've already been installed) how much do the standard dvr's run?
Please stick with one thread, no need for a new one just 2 days in.
The standard DVR is $99. The HD DVR is $199.
Anything less that that depends on the account, and you can call 800-DIRECTV to see if you can get it for any less.
Limited time offer
