Acronyms | SatelliteGuys.US
Acronyms
Ken11861
24
Littleton, MA
Is there a list of acronyms on the site?
I recently found out that a BBC "Broad band Converter".
Now I want to know what a "LOS" is
Cheers :confused:
For me "LOS" has at least two meanings and you get those from the context of how it's used. In one case LOS stands for Line of Sight and has to do with placement of the dish in order to have a clear view of the sky to pick up the satellite signals. The other meaning is Loss of Signal. Loss of signal can be from numerous causes so I won't even try to explain that here.
Ken,
If you want , you can look around in the "Glossary" that has a lot of that type of stuff in it as well as definitions of common terms.
Forum Jump, Chat Room, GLOSSARY .....
in the dark blue line just above the posts
Jimbo
Is buying the HD-DVR receiver from D*V the best deal going?
Switching Premium Channels
