AC3 Audio | SatelliteGuys.US
AC3 Audio
towerdude
SatelliteGuys Guru
127
54
SW COLORADO
What type of external sound cards are being used to decode AC3 audio? I have used the Creative Extigy Soundblaster, but those are becoming scarce on ebay .....
You can look up spid/f ac3 sound card converter and a lot of things will pop up. Prices and quality will vary. If all you want to do is hear the audio you don't need much. If you are recording, having several bitrate options may be important. Another option is getting a USB to PCI adapter/enclosure, then you will have a ton of other choices.
87W MeTV
Using both FTA and Dishnet receivers at the same time?
