AC3 Audio - Pansat 9200 HD | SatelliteGuys.US
ikki
922
12
Minnesota
Now that all my transponders are cleared, and channels I went ahead and added the following info.
97 WEST 11834 V 20770 APID 62 and PCR 62.
1. First question does this work for someone WITHOUT a Pansat
and
2. Next question does this work for someone WITH a Pansat
and
3. If you have a Pansat 9200 HD what software version are you using.
Additional Info:
Q is 88%
Working fine here on the Coolsat 5000
I did a TP scan and one of the radio channels is STAR1 and 2
Audio Pid 62
2 different tracks...have to separate them via the audio left and right button
the station isnt ac-3...its regular mpeg2
Thanks, so clearly I have some kind of software issue.
Know of a stable Pansat 9200 Bin (With or without PVR)
Using software version 1226, the only way I have been able to get it to pop in is to select Audio then select L or R exit out then press green button three times.
Like you stated it appears to be a software problem.
PS press the green button slowly about 1 sec between each
1st post
Art Bell Coast to Coast
