AC Power Required for DPP44 Install? | SatelliteGuys.US
Big D
48
3
I have a DPP44 switch install coming up and was wondering if I needed an AC outlet at the switch location in my attic? I could not find an install manual for the switch on the Dish site, so I do not know what is required.
Thanks, :confused:
That sounds better then in the attic. Does the power inserter come with the switch, or is it a separate item? I will have two 622's and a 721, I believe I need two separators as well, right?
Yes, you are correct. Make it 3 separators, 3 coax runs and a DPP44 to go please.
Wiring for 622?
Contracts for 622 upgrade?
