About to pull the trigger! | SatelliteGuys.US
philhu
1,215
Cold Boston Area
I bought a Neusat 6000 receiver, based upon Iceberg's review.
So I am about to pull the trigger on the following from Sadoun:
Fortec Star 90U dish (Their universal mount, in case I get a motor later)
QPH031 Quad ku/circular Invacom LNBF
PVTP3KIT 3ft self supporting tripod with pole (To play with finding a good location)
Does this look good?
Looks very good, I'm using a system very similar to that, just a different receiver a no tripod. You'll be satisfied! Well, let me take that back...you'll be happy and it'll make you hungry for more.
Those are good choices because (trust me) you will be lusting after a motor soon.
It's not a bad idea to first get everything working without a motor. Doing so takes one major variable out of the equation.
When choosing a permanent location for your fixed dish installation you might want to pick one with a good view of the arc, not just the bird(s) you are most interested in right now. I have a feeling that will save you some work in the near future.
Ok
Rcvr is shipped by Ebay member
Sadoun has shipped the dish and tripod.
FTA, here I come!
Now I just need to find a place to be able to see 123 (G10) in my forest!
DG-120A Motor Installation
30.0 West Hispasat Ku-Band
