ABC HD audio issues | SatelliteGuys.US
ABC HD audio issues
dsm4898
11
Seems like it happens more with ABC than any other. The audio synch was way off tonight for Gray's Anatomy and the pq was choppy/jerky.
Anyone else see this? What can be done? Should I go back to cable? It wasn't happening with TWC.
dsm
:confused:
Never noticed any problems on ABC, either OTA or on D*, personally. NBC, on the other hand....
Have you checked your signal strengths and/or do you get ABC OTA to check that out? It could be a problem with the local affiliate's signal and D* is just passing it through...
Hands-On with Directv's new HD
H20 Remote Problem
