a test for the 101 and the 95 satellite | SatelliteGuys.US
yujiro1982
38
2
new york
can I take two round dishes point one of them to the 101 and the other one to the 95 and combine it to the 4x4 multiswitch and get signal with the 101 and the 95
I know you can do it with the 101 and the 119, but I want to know if it is possible with the 101 and the 95
You won't get jack from 95 with a round OR oval dish (the 3LNB kind) - you must use the international dish made for it.
You will need & CAN use the 4x4 switch on the international dish.
Why won't the OP get anything from 95 with a round dish? The OP did mention the use of two dishes, one for each sat. What I'm unfamiliar with is if the LNB is the same for 95 as the 101 one.
Why not try it, if you have the equipment?
I hope someone can help me. . . . . .
sat coax and cable dont work
