a new version of channel Master is available v1.2.1 | SatelliteGuys.US
regisma
58
Hi,
I have just noticed that a new version of Channel Master is available:
Current version: 1.2.1 build May 7, 2005
Features:
- compatible with GTD file format (GTools)
- Copy/paste channels and satellites from another list
- Search for channels/satellites by name
- Print Channel line-up - with Templates
- Fill Missing Channels
- Pansat and Fortec Read/(Write still in beta as it hangs in some situations)
- Powerful bulk rename
- Renumber Channels
- Import/Export from/to SatcoDX Protocol format.
- Unlimited Favorites when using CM native XML format
- Apply Template and Create Template as per GTools Helper, extended with Ac3 info as in CTools.
- Global Satellite preferences that are applied when loading any project.
- Import/Export from/to BlackBird TXT and FCD formats.
- Import/Export from/to Digiwave TXT format.
- Support for NDF file format (Coolsat receivers).
- Import/Export from/to Spacestar DAT format.
- Import/Export from/to MyTheatre database.
Enjoy!
SharpC.
thanks
Reg
Not so Sure !
Thanks, the reason I came to this site was so I wouldn't have to go to others and as I look again I'm not so sure !!! Is this for True FTA Receivers or does this make it possible for D an D.? Don't need it if that is the case, already have one D, I am looking for FTA :confused:
Audio on The Tube or Fox News- Galaxy 3C
g10r
