A little help for my parents | SatelliteGuys.US
GEORGIARES
2
Hello I am new to the site, I hope someone can help. I am trying to save my parents a little money with their system, an RCA dual output LNB, standard round dish, Direct TV programming. The last few months they have had a harder and harder time getting some channels. The local channels are fine, Starz and HBO are ok, just occasional picture freeze. But Sci-Fi, History and many of the Discovery channels (my father's favorites) are next to impossible to get a signal on. We finally had Direct TV come out and look, the problem is the neighbor's pine trees have gotten too tall. The options the tech gave were to have the trees cut down, or to raise the dish some more. The main problem is that the dish is about 2 1/2 stories off the ground and there is nowhere else it could be put and get a better line of site. I have been looking for an extension pole to put on the factory mount (rather than paying a contractor to instal a flagpole size mounting pole) to raise the dish but no one can tell me how much the dish needs to be raised, whether that would cause reliability problems and how large the tubing the factory mount is made from is. I think if I can just add say 5 feet of height to the mount that it will work. Is the tubing 1 1/2, 1 3/4? If anyone can offer any help, or if anyone has any other solutions, it would be appreciated, and if more info from me is needed please let me know.
Marty
The tubing is 1 5/8 inch od.
Perfect 10 has 5' towers for under 20 bucks ,but I don't know if they will sell to the general public.
I have bought "1 5/8 inch fence top railing" that works perfectly. It comes in 10 foot sections. If you move the dish 6 to 7 feet it should be good for a few years depending on the growth rate of the pine. Or if you know someone that is a real good marksman the could "trim" the pine tree with thier gun providing they will not do any property damage below it. One other option is to switch to Dish Network if their line of site is better. They could get all new equipment and might be a longer lasting solution if there is less trees in the direction of the Dish Network satellites. Living in the south and installing these dishes can be challenging due to the tall pines.
BMSR1
DirecTV on existing cable lines?
Have new 3 LNB Dish w/ built in multiswitch I need 8 outputs
